A day in the life...
Re: A day in the life...
Received the Klein headset bearings today - yay!
Got them from https://www.kleinspainted.com in the UK.
They concentrate on Pre-Trek Kleins and do awesome paint jobs!
Maddel wrote: August 31st, 2022, 7:53 am Received the Klein headset bearings today - yay!
Man, those are some gorgeous frames. I've got a couple youtube subscriptions where they've tried sunburst paintjobs but nothing like that, that first pic looks like it had some lighting making it look like that.
the first one is reminding me of a big stick popcicle :D
Nowadays this '99 Manitou SX isn't considered to be a fork at all. :lol:
Anyway... It came with the Klein thus I'll keep it but with an updated design...
when you spot a Tow'd in the wild ;)
Super_Randy wrote: September 2nd, 2022, 7:55 pmwhen you spot a Tow'd in the wild ;)
^^^ 8-) Buggys are quite rare over here. The clime is not suitable I guess. Wait a minute... In a few years may be...
Cousin stopped by with her New Beetle...
Headset bearings and fork are back in...
I felt uneasy about the instructions given in the 1999 Klein tech manual to tap the top bearing into place.
So I made this redneck tool to press it into the head tube.
It worked surprisingly well I even forgot to take some pics of it attached to the frame. :D
Maddel wrote: September 3rd, 2022, 3:12 pmI felt uneasy about the instructions given in the 1999 Klein tech manual to tap the top bearing into place.
I made the same tool as you, although mine was less precise in construction. It has worked just fine for all of the headsets I've ever needed to press in.
Got the exterior framing inspection done so started roughing in some wiring in the kids apartment today. The wall is the easy part. Tomorrow will be attic space work(120+ f temps).
schwim wrote:... started roughing in some wiring in the kids apartment today.
Wow, very diligent & quite accurate. When it comes to wiring I'm lost for the most part...
Except for connecting a bulb may be. :D
schwim wrote:... Tomorrow will be attic space work(120+ f temps).
Now that's cozy... :shock:
That will be a sweaty mess... Hopefully not dealing with insulation materials.
Good luck!!
it was 108 here yesterday. went outside a few times, the humidity finally burned off about 2pm, so it was tolerable out if you were taking it easy in the shade. then by 8pm it was 80 degrees with 80% humidity and it was absolute F'ing miserable again. words can not describe how much i hate humidity.
The right coast is so used to humidity, it's just part of the outdoor experience. Being completely soaked in sweat while working in 90 degrees is the crappiest way to spend the day.
